Ir para o conteúdo principal
Lenovo Thinkpad E540 Fan Replacement
O que você precisa
  1. Lenovo Thinkpad E540 Fan Replacement, Battery: passo 1, imagem 1 %32 Lenovo Thinkpad E540 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Fan Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. Lenovo Thinkpad E540 Fan Replacement, Disassembly of the Back Panel: passo 3, imagem 1 %32
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
  4. Lenovo Thinkpad E540 Fan Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Fan Replacement, Fan: passo 5, imagem 1 %32
    • Heatsink and fan are connected. You have to remove both at the same time.
    • The heatsink and fan are found on the right side.
  6. Lenovo Thinkpad E540 Fan Replacement: passo 6, imagem 1 %32
    • Remove the two 1mm Phillips #0 screws from the fan.
    • Unscrew the four 2mm Phillips s#0 screws from the heatsink.
    • The screws on the heatsink will stay attached to it.
  7. Lenovo Thinkpad E540 Fan Replacement: passo 7, imagem 1 %32
    • To remove the heatsink and fan, pull the fan upwards and towards the center.
Conclusão
Timothy Sumner
Membro desde: 02/14/18
1.046 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membro de USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 25
Duração total: 2,463
