Introdução
Use this guide to replace a fan inside of a Lenovo ThinkCentre M83 SFF computer to prevent overheating and further damage to your computer.
If your Lenovo ThinkCentre M83 SFF Pro Desktop computer is overheating, there might be an issue with your internal fan. Replacing a fan inside a computer can help improve the overall performance and longevity of the system. The fan is responsible for cooling the various components within the computer, such as the CPU and GPU. If a fan becomes defective, it can negatively impact the effectiveness of the computer and lead to overheating.
Before using this guide, inspect the computer fan for dust and debris. This may also cause it to malfunction and not work. A small build-up of dust can be removed by using a small dust blower.
Before beginning this repair, be sure to turn off the device, and unplug from the power adapter.
O que você precisa
Your device should be reassembled by following the final step.
