Ir para o conteúdo principal
Lenovo Thinkcentre M83 SFF Fan Replacement
O que você precisa
  1. Lenovo Thinkcentre M83 SFF Fan Replacement, Fan: passo 1, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement, Fan: passo 1, imagem 2 %32
    • Disconnect all of the cables connected to the computer.
  2. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 2, imagem 1 %32
    • Lay the computer on its side.
    • Unscrew the 14.0 mm screw with your hands to remove the side panel.
  3. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 3, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 3, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 3, imagem 3 %32
    • To remove the side panel press the release button and slide the cover to the rear of the computer.
  4. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 4, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 4, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 4, imagem 3 %32
    • Remove the fan cover by pushing the two tabs out slightly with your hands, and lifting the cover up gently.
  5. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 5, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 5, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 5, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove four 12.0 mm screws securing the fan to the heat sink.
  6. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 6, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 6, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 6, imagem 3 %32
    • Pull the bundled fan cable away from the connector in the same direction as the individual wires are running to detach the fan from the motherboard.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Lift the fan out from the motherboard.
  7. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 7, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 7, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 7, imagem 3 %32
    • Place the new fan on top of the heat sink and position it so that it aligns with the screw holes.
    • Use a Phillips #0 screwdriver to replace the four 12 mm screws that secure the fan.
    • Do not over tighten the screws.
  8. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 8, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 8, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 8, imagem 3 %32
    • Clip the new fan's cable connector into the motherboard socket by aligning the pins together and pushing down.
    • Don't jam the connector down as the pins can be damaged if they are not lined up properly.
  9. Lenovo Thinkcentre M83 SFF Fan Replacement: passo 9, imagem 1 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 9, imagem 2 %32 Lenovo Thinkcentre M83 SFF Fan Replacement: passo 9, imagem 3 %32
    • Place the fan cover back on.
    • Slide the computers cover panel into place.
    • Screw the 14 mm screw back in with your hands.
Conclusão
Your device should be reassembled by following the final step.
Equipe
Um comentário
Replacing the CPU fan on the Lenovo M700 SFF is easy. But to replace the case fan one requires either an advanced degree in Lenovo tech OR, membership of the Grande Obscure Guild of PC Case Fan Replacers.
mark4asp - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 58
Duração total: 852
