Introdução
Before reading this guide on how to replace the keyboard for the Lenovo ThinkPad x120e, check the “Keyboard Not Responding” section on the device’s troubleshooting page to see if your issue can be fixed without replacement: Lenovo ThinkPad x120e Troubleshooting - iFixit
Reminder: make sure you turn off your laptop and remove any attached power cables before beginning..
O que você precisa
Flip the laptop upside down and locate the battery latches under the battery.
Place your thumbs on both latches and push the latch inwards.
With your thumbs still on the latches, slide the battery out of the laptop.
Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
Remove the backplate carefully, making sure not to bend the cover.
Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
