O que você precisa
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove two screws using a Phillips #1 screwdriver.
Pull the hard drive horizontally in the direction of where the battery was located.
Quase terminado!
Conclusão
