Ir para o conteúdo principal
Lenovo ThinkPad Yoga 370 Touchpad Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 370 Touchpad Replacement, Touchpad: passo 1, imagem 1 %32
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 2, imagem 2 %32
    • Using the Phillips #00 screwdriver, unscrew the eight 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 3, imagem 2 %32
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 4, imagem 2 %32
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 5, imagem 3 %32
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 6, imagem 3 %32
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
  7. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the Phillips #00 screwdriver, remove the four 4mm screws.
    • Using tweezers or your fingers, gently undo the connection between the touchpad and the motherboard.
  8. Lenovo ThinkPad Yoga 370 Touchpad Replacement: passo 8, imagem 1 %32
    • Turn the device over to the front side.
    • Using a plastic opening tool, gently remove the touchpad.
Conclusão
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 47
Duração total: 2,840
