Ir para o conteúdo principal
Lenovo ThinkPad Yoga 370 Screen Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 370 Screen Replacement: passo 2, imagem 2 %32
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 4, imagem 1 %32
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 370 Screen Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 370 Screen Replacement: passo 5, imagem 3 %32
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 81
Duração total: 2,126
