Ir para o conteúdo principal
Lenovo ThinkPad Yoga 370 Fan Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 370 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 2, imagem 2 %32
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 3, imagem 2 %32
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 4, imagem 2 %32
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 5, imagem 3 %32
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 6, imagem 3 %32
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fan Replacement, Fan: passo 7, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement, Fan: passo 7, imagem 2 %32
    • Remove the four 2 mm screws holding the heatsink to the motherboard using the Phillips #00 screwdriver.
  8. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the fan's bundled cable from the motherboard using a small set of tweezers or simply pull them out gently.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  9. Lenovo ThinkPad Yoga 370 Fan Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad Yoga 370 Fan Replacement: passo 9, imagem 2 %32
    • The fan is not ready to be removed yet. When lifting the fan from the frame, keep it within 2 inches from the motherboard until the attached wire is removed.
    • Lift the fan and heatsink from the motherboard; then flip both toward the motherboard.
    • Detach the wire from the perimeter of the fan casing.
    • Remove the fan and heatsink.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 43
Duração total: 788
