Ir para o conteúdo principal
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 3, imagem 2 %32
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 4, imagem 2 %32
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: passo 5, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 6, imagem 2 %32
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 7, imagem 2 %32
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Duração total: 905
