Ir para o conteúdo principal
Lenovo ThinkPad Yoga 260 Trackpad Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 3, imagem 2 %32
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 4, imagem 2 %32
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: passo 5, imagem 3 %32
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 6, imagem 3 %32
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: passo 7, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: passo 7, imagem 2 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: passo 7, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
  8. Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 8, imagem 2 %32
    • Using your index finger and thumb gently pull the blue tab located at the top of the trackpad back from the assembly.
  9. Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad Yoga 260 Trackpad Replacement: passo 9, imagem 3 %32
    • Flip the device right side up.
    • Open the computer.
    • Gently lift the trackpad out of the computer assembly.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,321
