Ir para o conteúdo principal
Lenovo ThinkPad Yoga 260 Motherboard Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 3, imagem 2 %32
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 4, imagem 2 %32
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: passo 5, imagem 3 %32
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 6, imagem 3 %32
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: passo 7, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: passo 7, imagem 2 %32
    • Using both thumbs, pinch the RAM's mounting clips outward.
    • The RAM module will spring up on its own.
  8. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 8, imagem 1 %32
    • Gently remove it from its mounting.
  9. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: passo 9, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: passo 9, imagem 2 %32
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  10. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 10, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  11. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 11, imagem 1 %32
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
  12. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: passo 12, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: passo 12, imagem 2 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: passo 12, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  13. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 13, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 13, imagem 2 %32
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  14. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 14, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 14, imagem 2 %32
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
  15. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: passo 15, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: passo 15, imagem 2 %32
    • Disconnect the speaker cable located near hinge side of the laptop.
    • Remove both speakers from the assembly.
  16. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 16, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 16, imagem 2 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 16, imagem 3 %32
    • Gently lift up the SD chip's black protective film.
    • Unplug the SD chip from the assembly and set the SD chip aside.
  17. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 17, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 17, imagem 2 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 17, imagem 3 %32
    • Pull up on the 2 black tabs to remove the cords located along the hinge edge of the device.
  18. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 18, imagem 1 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 18, imagem 2 %32 Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 18, imagem 3 %32
    • Pull up the 6 colored tabs along the edge of the motherboard to disconnect them from the motherboard.
  19. Lenovo ThinkPad Yoga 260 Motherboard Replacement: passo 19, imagem 1 %32
    • Remove the fourteen .8 mm screws on the motherboard using a Phillips #00 screwdriver.
    • Carefully lift the motherboard out of assembly.
    • Ensure no wires or cables remain connected.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 51
Duração total: 2,273
