Ir para o conteúdo principal
Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Unplug and completely shut down your computer beforehand to reduce the risk of electric shock.
    • Flip the laptop over so you can see the bottom panel.
    • Unscrew the circled screws to detach the keyboard.
  2. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 2, imagem 3 %32
    • Flip the laptop back over and open it normally.
    • Use a plastic opening tool to lift up the keyboard along the bottom edge until it is detached.
  3. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 3, imagem 2 %32
    • Using a finger, push the top of the keyboard out of its holder to completely detach it.
    • Move the keyboard out of the way by rotating the far side of the keyboard towards you.
  4. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 4, imagem 2 %32
    • Be gentle! These connectors are very small and can easily break off.
    • Lay the keyboard on its front.
    • Disconnect the 3 cables by pulling on the attached tabs.
Conclusão
3 outras pessoas executaram este guia.
Sarthak Khillon
Membro desde: 04/12/17
259 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S14-G2, Banghart Spring 2017 Membro de Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 5,550
