Ir para o conteúdo principal
Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement, LCD: passo 1, imagem 1 %32
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 2, imagem 2 %32
    • Use a T5 screwdriver to remove the two 7.62 mm screws circled in red at the bottom of the front of the display.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 3, imagem 3 %32
    • Heat up the iopener and apply it to all 4 edges of the display
    • Be cautious when handling the iopener as the contents are hot and follow the instructions written on the product.
    • You might need to heat up the iopener multiple times to melt the glue holding the dsoplay in place
  4. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 4, imagem 2 %32
    • Use the Jimmy pick knife to pry the display open all around.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: passo 5, imagem 3 %32
    • Finally, unplug the 2 connection points of the display from the motherboard.
    • The big port will have a silver latch that needs to be flipped up for the port to come out.
    • You can now replace the old display with the new one.
Conclusão
Onel
Membro desde: 02/04/24
173 Reputação
Autoria de 1 guia
Equipe
Gateway, Team 11-11, Gonzalez Spring 2024 Membro de Gateway, Team 11-11, Gonzalez Spring 2024
GCC-GONZALEZ-S24S11G11
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 27
