Ir para o conteúdo principal
Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement
O que você precisa
  1. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement, Battery: passo 1, imagem 1 %32
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 2, imagem 3 %32
    • Use a T5 Torx screwdriver to loosen and remove all eight bottom cover screws.
    • If you're having issues removing the bottom cover, be sure to use the opening pick to pry the case open carefully.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 3, imagem 2 %32
    • Unplug the battery from the motherboard. This will need to be done before removing the battery screws.
    • The connection point is shown circled in yellow.
    • Pull the strip out, it might require some force and wiggling.
  4. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 4, imagem 2 %32
    • Remove the screws holding the battery in place. There are 5 screws that need to be removed.
    • Using the same screwdriver and bit as before, remove all the screws and keep them somewhere safe.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery
    • The battery is latched on so it will require some force to pop it out.
Conclusão
David Beltran Heredia
Membro desde: 02/02/24
229 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 11-11, Gonzalez Spring 2024 Membro de Gateway, Team 11-11, Gonzalez Spring 2024
GCC-GONZALEZ-S24S11G11
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 36
Duração total: 115
