Ir para o conteúdo principal
Lenovo ThinkPad X61 Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X61 Battery Replacement, Battery: passo 1, imagem 1 %32
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Lenovo ThinkPad X61 Battery Replacement: passo 2, imagem 1 %32
    • The next step is to simply move the switch from the locked position to the unlocked position.
  3. Lenovo ThinkPad X61 Battery Replacement: passo 3, imagem 1 %32
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
Conclusão
Ryan McCarthy
Membro desde: 03/15/18
772 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 1,109
