Ir para o conteúdo principal
Lenovo ThinkPad X390 Yoga Touchpad Replacement
O que você precisa
  1. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Back Case: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Touchpad Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Touchpad Replacement: passo 3, imagem 1 %32
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Battery: passo 4, imagem 1 %32
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Touchpad Replacement: passo 5, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Touchpad Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Touchpad: passo 7, imagem 1 %32
    • Disconnect the touchpad ribbon connector from the motherboard using the opening tool.
  8. Lenovo ThinkPad X390 Yoga Touchpad Replacement: passo 8, imagem 1 %32
    • Remove the four 4 mm screws using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Touchpad Replacement: passo 9, imagem 1 %32
    • Carefully open the laptop and remove the touchpad.
Conclusão
Tanner Baine
Membro desde: 09/03/21
423 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 649
