Ir para o conteúdo principal
Lenovo ThinkPad X390 Yoga SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X390 Yoga SSD Replacement, Back Case: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga SSD Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga SSD Replacement: passo 3, imagem 1 %32
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga SSD Replacement, SSD: passo 4, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the 4 mm screw holding the SSD in place .
  5. Lenovo ThinkPad X390 Yoga SSD Replacement: passo 5, imagem 1 %32
    • Pull the SSD out from the connection to remove it.
Conclusão
Scott Merchant
Membro desde: 09/03/21
90 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 85
Duração total: 1,412
