Ir para o conteúdo principal
Lenovo ThinkPad X390 Yoga Motherboard Replacement
O que você precisa
  1. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Back Case: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 3, imagem 1 %32
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Battery: passo 4, imagem 1 %32
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 5, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Fan: passo 7, imagem 1 %32
    • Disconnect the fan connector from the moetherboard with a spudger or opening tool.
  8. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 8, imagem 1 %32
    • Loosen the seven screws surrounding the fan and heatsink using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 9, imagem 1 %32
    • Carefully remove the fan from the laptop by lifting it up and off the frame.
  10. Lenovo ThinkPad X390 Yoga Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Disconnect the motherboard connectors with a spudger or opening tool.
  11. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 11, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove nine 5 mm screws around the motherboard.
  12. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 12, imagem 1 %32
    • Loosen the sixty-eight 2 mm screws using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad X390 Yoga Motherboard Replacement: passo 13, imagem 1 %32
    • Carefully remove the motherboard from the laptop by lifting it up and off the frame.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 45
Duração total: 568
