Ir para o conteúdo principal
Lenovo ThinkPad X390 Yoga Display Replacement
O que você precisa
  1. Lenovo ThinkPad X390 Yoga Display Replacement, Back Case: passo 1, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Display Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Display Replacement: passo 3, imagem 1 %32
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Display Replacement, Display: passo 4, imagem 1 %32 Lenovo ThinkPad X390 Yoga Display Replacement, Display: passo 4, imagem 2 %32
    • Disconnect the display connectors with a spudger or opening tool.
  5. Lenovo ThinkPad X390 Yoga Display Replacement: passo 5, imagem 1 %32
    • Loosen the two 5.5mm screws using the Phillips #1 screwdriver.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 70
Duração total: 706
