Ir para o conteúdo principal
Lenovo ThinkPad X390 SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X390 SSD Replacement, SSD: passo 1, imagem 1 %32
    • Shut down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five 2.7 mm screws on the base cover.
  2. Lenovo ThinkPad X390 SSD Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 SSD Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 SSD Replacement: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 SSD Replacement: passo 5, imagem 1 %32
    • Using your hands, remove the battery from the laptop.
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 SSD Replacement: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the SSD to the motherboard.
  7. Lenovo ThinkPad X390 SSD Replacement: passo 7, imagem 1 %32
    • Grip the SSD, and gently pull it directly out of its port.
Conclusão
1Comentário do guia
I have been building computers for 15+ years, i didn't go to a fancy college but even I know this tutorial is for replacing the SSD or M.2 to be specific for a X390 laptop. this is not the ram module
Patrick Timmel - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 131
Ao todo: 5,685
