Ir para o conteúdo principal
Lenovo ThinkPad X390 Fan Replacement
O que você precisa
  1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Fan Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X390 Fan Replacement: passo 2, imagem 2 %32
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Unplug the fan connector from the motherboard.
  4. Lenovo ThinkPad X390 Fan Replacement: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
  5. Lenovo ThinkPad X390 Fan Replacement: passo 5, imagem 1 %32
    • Lift the fan up and out and remove it from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Couch
Membro desde: 09/28/21
252 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 5-1, Hunter Fall 2021 Membro de Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 48
Duração total: 940
