Ir para o conteúdo principal
Lenovo ThinkPad X280 Fan Assembly Replacement
O que você precisa
  1. Lenovo ThinkPad X280 Fan Assembly Replacement, Back Panel: passo 1, imagem 1 %32
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Fan Assembly Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X280 Fan Assembly Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Fan Assembly Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X280 Fan Assembly Replacement: passo 3, imagem 2 %32
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: passo 4, imagem 1 %32 Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, loosen the four captive screws attached to the heat sink until a small pop sound heard.
    • The screws do not come all the way out and remain partially attached to the heat sink.
  5. Lenovo ThinkPad X280 Fan Assembly Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X280 Fan Assembly Replacement: passo 5, imagem 2 %32
    • Using the black spudger, gently push out the gray plastic connecter from the plug.
  6. Lenovo ThinkPad X280 Fan Assembly Replacement: passo 6, imagem 1 %32
    • Loosen and remove the fan.
Conclusão
Jordan Wooten
Membro desde: 09/05/21
588 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 26
Últimos 30 dias: 72
Duração total: 2,171
