Introdução
This will take approximately 50 minutes to complete from beginning to end.
O que você precisa
Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
Remove the battery.
Use tweezers to gently unplug the CMOS Battery from the port on the right side.
