Ir para o conteúdo principal
Lenovo ThinkPad X270 Back Cover Replacement
O que você precisa
  1. Lenovo ThinkPad X270 Back Cover Replacement, Remove the micro SIM card tray: passo 1, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Remove the micro SIM card tray: passo 1, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Remove the micro SIM card tray: passo 1, imagem 3 %32
    • A SIM eject tool or bit isn't long enough to eject the tray.
    • Insert a straightened paper clip into the micro SIM card tray hole on the right edge of the laptop.
    • Press the paper clip firmly into the hole to eject the tray.
    • Remove the tray.
    • When reinserting the tray, slide the arms of the tray into the rectangular metal slot.
  2. Lenovo ThinkPad X270 Back Cover Replacement, Battery information: passo 2, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Battery information: passo 2, imagem 2 %32
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  3. Lenovo ThinkPad X270 Back Cover Replacement, Release the left tab: passo 3, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the left tab: passo 3, imagem 2 %32
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  4. Lenovo ThinkPad X270 Back Cover Replacement, Remove the battery: passo 4, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Remove the battery: passo 4, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Remove the battery: passo 4, imagem 3 %32
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  5. Lenovo ThinkPad X270 Back Cover Replacement, Unfasten the back cover: passo 5, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Unfasten the back cover: passo 5, imagem 2 %32
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
    • Don't try to completely remove the screws—they're secured to the back cover with delicate, plastic clips.
  6. Lenovo ThinkPad X270 Back Cover Replacement, Insert an opening pick: passo 6, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Insert an opening pick: passo 6, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the bottom right edge of the back cover and frame.
    • Pry up the back cover to release the bottom right clips.
    • Leave the pick inserted in the bottom right corner.
  7. Lenovo ThinkPad X270 Back Cover Replacement, Release the bottom edge clips: passo 7, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the bottom edge clips: passo 7, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the bottom edge clips: passo 7, imagem 3 %32
    • During the next two steps, position your pick downward at a 45-degree angle to help release the clips.
    • Slide the pick to the bottom left corner to release the bottom clips.
  8. Lenovo ThinkPad X270 Back Cover Replacement, Release the left edge clips: passo 8, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the left edge clips: passo 8, imagem 2 %32
    • Insert your pick in the bottom left corner and slide the pick to the first USB port to release the left clips.
  9. Lenovo ThinkPad X270 Back Cover Replacement, Release the top corner clips: passo 9, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the top corner clips: passo 9, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the top corner clips: passo 9, imagem 3 %32
    • Insert an opening tool between the top left corner of the back cover and frame.
    • Pry the back cover up to release the clips securing its top left corner.
    • Repeat the process on the top right corner.
  10. Lenovo ThinkPad X270 Back Cover Replacement, Release the top edge clips: passo 10, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the top edge clips: passo 10, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Release the top edge clips: passo 10, imagem 3 %32
    • Five clips secure the top edge of the back cover.
    • Insert an opening tool in the gap between the back cover and frame, next to one of the clips.
    • Push the opening tool into the gap until the clip releases.
  11. Lenovo ThinkPad X270 Back Cover Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement: passo 11, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement: passo 11, imagem 3 %32
    • Push the opening tool between the back cover and frame at different points along the top edge to release the remaining clips.
  12. Lenovo ThinkPad X270 Back Cover Replacement, Remove the back cover: passo 12, imagem 1 %32 Lenovo ThinkPad X270 Back Cover Replacement, Remove the back cover: passo 12, imagem 2 %32 Lenovo ThinkPad X270 Back Cover Replacement, Remove the back cover: passo 12, imagem 3 %32
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
Conclusão
Uma outra pessoa concluiu este guia.
Spencer Day
Membro desde: 09/14/22
61.613 Reputação
Autoria de 445 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.079 guias
Um comentário
Świetny poradnik. Polecam
Adam Wiśniewski - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 27
Duração total: 478
