Ir para o conteúdo principal
Lenovo ThinkPad X250 Thermal Paste Replacement
O que você precisa
  1. Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel: passo 1, imagem 1 %32 Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel: passo 1, imagem 2 %32 Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel: passo 1, imagem 3 %32
    • Unscrew the 8 screws holding the back panel in place.
    • Use a plastic prying tool to release all the clips holding the panel in place.
    • Remove the first battery by sliding the notches and pulling the battery outwards.
  2. Lenovo ThinkPad X250 Thermal Paste Replacement, Disconnect the internal battery: passo 2, imagem 1 %32
    • It is recommended to disconnect the second battery.
    • Disconnect the wire from the motherboard.
  3. Lenovo ThinkPad X250 Thermal Paste Replacement, Removing the CPU cooler: passo 3, imagem 1 %32 Lenovo ThinkPad X250 Thermal Paste Replacement, Removing the CPU cooler: passo 3, imagem 2 %32
    • Unscrew the 4 screws holding the CPU cooler. Disconnect the fan cable by releasing the latch on the connector and pulling the cable out.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton buds or paper towel, be careful not to go too hard on the CPU.
  4. Lenovo ThinkPad X250 Thermal Paste Replacement, Apply new thermal paste: passo 4, imagem 1 %32 Lenovo ThinkPad X250 Thermal Paste Replacement, Apply new thermal paste: passo 4, imagem 2 %32 Lenovo ThinkPad X250 Thermal Paste Replacement, Apply new thermal paste: passo 4, imagem 3 %32
    • Once you have removed the old thermal paste, it's time to apply the new paste. This model has a hole in the heatsink so it does not need thermal paste applied on the smaller pad.
    • Do not use too much thermal paste, just enough to cover the bigger portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Put the heatsink back carefully and tighten the screws in order 1, 3, 2, 4 to ensure even pressure. Don't forget to plug in the fan cable again.
  5. Lenovo ThinkPad X250 Thermal Paste Replacement, Clean your laptop: passo 5, imagem 1 %32
    • It is recommended to use compressed air to remove any dust in the laptop and the fan.
    • Don't forget to plug in the second battery before closing the back panel!
Conclusão
5 outras pessoas executaram este guia.
Simeon Brankov
Membro desde: 11/08/20
7.153 Reputação
Autoria de 54 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 84
Duração total: 4,820
