Ir para o conteúdo principal
Lenovo ThinkPad X140e Speakers Replacement
O que você precisa
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: passo 1, imagem 1 %32
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 2, imagem 2 %32
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 3, imagem 3 %32
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 4, imagem 3 %32
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 6, imagem 2 %32
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 7, imagem 2 %32
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad X140e Speakers Replacement: passo 8, imagem 3 %32
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
Conclusão
Dylan Halland
Membro desde: 10/05/16
324 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-5, Livingston Fall 2016 Membro de Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 2,970
