Ir para o conteúdo principal
Lenovo ThinkPad X140e Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: passo 2, imagem 1 %32
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X140e Battery Replacement: passo 3, imagem 2 %32
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Conclusão
Dylan Halland
Membro desde: 10/05/16
318 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-5, Livingston Fall 2016 Membro de Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
Membros da 4
Autoria de 5 guias
Um comentário
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 951
