Ir para o conteúdo principal
Lenovo ThinkPad X100e Screen Replacement
O que você precisa
    • Use a Spudger tool to remove the screw covers on each side of the screen.
    • Be sure not to lose screw covers.
  1. Lenovo ThinkPad X100e Screen Replacement: passo 2, imagem 1 %32
    • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
  2. Lenovo ThinkPad X100e Screen Replacement: passo 3, imagem 1 %32
    • Pry open the bezel carefully with the spudger tool.
    • You will want to do this until the frame is completely off.
  3. Lenovo ThinkPad X100e Screen Replacement: passo 4, imagem 1 %32
    • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Be sure to set the screws aside on the magnetic mat.
  4. Lenovo ThinkPad X100e Screen Replacement: passo 5, imagem 1 %32
    • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • The other two screws are located in the exact place on the other side.
    • Don't forget to place the screws on the magnetic mat, separate from other screws.
  5. Lenovo ThinkPad X100e Screen Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X100e Screen Replacement: passo 6, imagem 2 %32
    • Remove the connector located at the very top of the screen beside the webcam.
    • To remove the connector, simply pull the connector out.
  6. Lenovo ThinkPad X100e Screen Replacement: passo 7, imagem 1 %32
    • Fold the panel over until a strip of black tape is visible.
    • Peel the tape down until you get to the base.
  7. Lenovo ThinkPad X100e Screen Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X100e Screen Replacement: passo 8, imagem 2 %32
    • Peel the piece of transparent tape back.
    • At this point there should be some exposed wires underneath the tape.
  8. Lenovo ThinkPad X100e Screen Replacement: passo 9, imagem 1 %32
    • Remove the connector carefully with the spudger tool.
  9. Lenovo ThinkPad X100e Screen Replacement: passo 10, imagem 1 %32
    • Remove the black tape fully.
    • Now your device is ready for a new panel.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 711
