Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga Speaker Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Yoga Speaker Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Yoga Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Speaker Replacement, Speakers: passo 2, imagem 1 %32
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Speaker Replacement: passo 3, imagem 1 %32
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Speaker Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Yoga Speaker Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Yoga Speaker Replacement: passo 4, imagem 3 %32
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 14
Últimos 30 dias: 44
Duração total: 1,958
