Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement, Speakers: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement, Speakers: passo 4, imagem 2 %32
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/Angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 5, imagem 2 %32
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 6, imagem 2 %32
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement, Battery: passo 7, imagem 1 %32
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 8, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 9, imagem 1 %32
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement, Touch ID: passo 10, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement, Touch ID: passo 10, imagem 2 %32
    • Use a metal spudger to lift the tab containing the black ribbon cable.
    • Do not use the metal spudger unless if it's used for serious prying power. The metal spudger may damage or puncture the internal components in the device, so please use the plastic opening tools or the nylon spudger instead.
    • Use nylon-tipped reverse tweezers to slowly pull out the ribbon cable.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 11, imagem 1 %32
    • Remove two 4 mm screws using the Phillips #0 screwdriver.
  12. Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Touch ID Replacement: passo 12, imagem 2 %32
    • Remove the gray covering from the Touch ID.
    • Remove the Touch ID chip from the device.
Conclusão
Alex Shacoski
Membro desde: 02/10/20
267 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team S22-G3, Regan Winter 2020 Membro de Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Membros
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 356
