Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Speakers: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Speakers: passo 4, imagem 2 %32
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/Angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 5, imagem 2 %32
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 6, imagem 2 %32
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Battery: passo 7, imagem 1 %32
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 8, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 9, imagem 1 %32
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Fan: passo 10, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Fan: passo 10, imagem 2 %32
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 11, imagem 1 %32
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  12. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 12, imagem 2 %32
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
  13. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Mother Board: passo 13, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove all 16 of the 6 mm screws connecting the motherboard to the computer.
  14. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 14, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 14, imagem 2 %32
    • Using the nylon spudger, disconnect the grey and black wires.
    • Using the nylon spudger, gently disconnect the pink tab from the motherboard.
  15. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 15, imagem 1 %32
    • Carefully remove the black tape with your fingers.
    • Do not remove the sticky residue from the back of the section.
  16. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 16, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 16, imagem 2 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 16, imagem 3 %32
    • Lift the Black flap using a plastic spudger.
    • Pull out the ribbon cable with the black tab.
  17. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 17, imagem 1 %32
    • Remove the purple tab by gently pulling it out.
  18. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 18, imagem 1 %32
    • Remove the blue tab by gently pulling it out.
  19. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 19, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 19, imagem 2 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 19, imagem 3 %32
    • Gently lift up on the sides with your hands and remove the motherboard.
  20. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement, Screen Assembly: passo 20, imagem 1 %32
    • Using a Phillips #0 Screwdriver, remove the two screws securing the hinges to the back panel.
  21. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 21, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 21, imagem 2 %32
    • Using a metal spudger, pry the hinge open forcefully until it is clear of the back panel.
  22. Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 22, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation Screen Assembly Replacement: passo 22, imagem 2 %32
    • Slide the back panel away from the monitor carefully.
    • The monitor should separate from the back panel easily if the hinges were pried far enough away from the panel.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 64
Duração total: 2,248
