Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 3, imagem 1 %32
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, SSD: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove one 6 mm screw.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 5, imagem 2 %32
    • Slide the SSD out of the shiny covering.
    • Remove the SSD.
Conclusão
9 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S22-G3, Regan Winter 2020 Membro de Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Membros
Autoria de 11 guias
1Comentário do guia
What kind of SSD is this compatible with? There are several different connector standards…
Shai Revzen - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 70
Ao todo: 8,879
