Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: passo 2, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: passo 3, imagem 1 %32
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 32
Últimos 30 dias: 72
Ao todo: 1,674
