Ir para o conteúdo principal
Lenovo ThinkPad X1 Yoga (6th Gen) Fan Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: passo 2, imagem 2 %32
    • Use a Phillips #000 screwdriver to loosen the four 5 mm captive screws.
    • The captive screws will stay attached to the fan as you remove it.
  3. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: passo 3, imagem 2 %32 Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: passo 3, imagem 3 %32
    • Place the pointed tip of a spudger behind the small plastic tab on either side, and "walk" the fan's connector out of its port, alternating between tabs, until the plug disconnects.
    • Lift the fan up and out.
Conclusão
Um comentário
Hi, Do you know what is the fan part number? Where did you get the fan from?
hamedabedi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 36
Duração total: 579
