Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme Speakers Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: passo 2, imagem 1 %32
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: passo 3, imagem 1 %32
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
77.584 Reputação
Autoria de 184 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 16.239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 295
