Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: passo 2, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Extreme SSD Replacement: passo 3, imagem 2 %32
    • Using the opening tool, pop out the SSD card and remove it from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 46
Ao todo: 2,317
