Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme RAM Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: passo 2, imagem 1 %32
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: passo 3, imagem 1 %32
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 817
