Introdução
This guide help you replace a failed or damaged keyboard. If you spill a drink or over a long period of time dirt can build up and prevent the keys from operating properly.
O que você precisa
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
Use a Phillips #00 screwdriver to remove the two 3 mm screws.
Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
Remove the silver plate on top of the charging port.
Use your fingernail or a nylon spudger to lift up the small locking flaps on the two ZIF connectors, then gently pull the ribbon cables directly out of their ports.
