Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme Hinges Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Hinges Replacement, Speakers: passo 2, imagem 1 %32
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Hinges Replacement: passo 3, imagem 1 %32
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: passo 4, imagem 3 %32
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Hinges Replacement: passo 5, imagem 1 %32
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: passo 6, imagem 2 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: passo 6, imagem 3 %32
    • Remove back panel and locate the connecting wires.
    • Disconnect the display connections on the motherboard.
    • Use a Phillips #00 screwdriver to remove the six screws (three on each hinge) securing the hinges to the main chassis.
  7. Lenovo ThinkPad X1 Extreme Hinges Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad X1 Extreme Hinges Replacement: passo 7, imagem 3 %32
    • Flip the display face up, then wedge a Jimmy between the display and the bezel, sliding and prying around the perimeter until the bezel releases.
    • Unscrew the first two exposed 1.2 mm screws with a Phillips #1 screwdriver, then peel back the adhesive to find and remove the third screw.
    • Lift the hinges up and off the display.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 642
