Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme Docking Station Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Speakers: passo 2, imagem 1 %32
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 3, imagem 1 %32
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Battery: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Battery: passo 4, imagem 3 %32
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 5, imagem 1 %32
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Fan: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Fan: passo 6, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Fan: passo 6, imagem 3 %32
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  7. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 7, imagem 2 %32
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  8. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 8, imagem 2 %32
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  9. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 9, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 9, imagem 3 %32
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  10. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Motherboard: passo 10, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Motherboard: passo 10, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Motherboard: passo 10, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
    • Remove the silver plate on top of the charging port.
  11. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 11, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 11, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 11, imagem 3 %32
    • Disconnect all the ribbon wires from the motherboard.
    • All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
  12. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 12, imagem 2 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 12, imagem 3 %32
    • Disconnect the black attachment at the top right corner of the motherboard.
    • Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip.
    • While maintaining pressure, gently pull on the wire that is connected to it to remove it.
  13. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 13, imagem 1 %32
    • Gently lift the motherboard out of the computer.
  14. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Docking Station: passo 14, imagem 1 %32
    • Once you have the motherboard removed, you now have access to the docking stations.
  15. Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 15, imagem 1 %32 Lenovo ThinkPad X1 Extreme Docking Station Replacement: passo 15, imagem 2 %32
    • Gently push the docking station towards the center of the motherboard, lift up to release a lock, then pull it out to remove it from the device.
Conclusão
Beckham Richmond
Membro desde: 02/10/20
462 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S7-G3, Regan Winter 2020 Membro de Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 762
