Ir para o conteúdo principal
Lenovo ThinkPad X1 Extreme Camera Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Camera Replacement, Speakers: passo 2, imagem 1 %32
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Camera Replacement: passo 3, imagem 1 %32
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Camera Replacement: passo 5, imagem 1 %32
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Camera Replacement, Display: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Extreme Camera Replacement, Display: passo 6, imagem 2 %32
    • Gently take off the cover of the hinge of the computer with a combination of the opening tool and your hands.
  7. Lenovo ThinkPad X1 Extreme Camera Replacement: passo 7, imagem 1 %32
    • Lift up the covering of the display using the opening tool.
  8. Lenovo ThinkPad X1 Extreme Camera Replacement: passo 8, imagem 1 %32
    • Use a spudger to release the retaining flap on the cable connector.
  9. Lenovo ThinkPad X1 Extreme Camera Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad X1 Extreme Camera Replacement: passo 9, imagem 2 %32
    • Pull the wire that was connected to the retaining flap through the hinge.
    • Remove the display from the laptop.
  10. Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: passo 10, imagem 1 %32 Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: passo 10, imagem 2 %32
    • Detach the wire that's connected to the camera.
    • Remove the camera.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 35
Duração total: 652
