Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Back cover removal: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Back cover removal: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Insert an opening pick: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Insert an opening pick: passo 2, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Remove the back cover: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Remove the back cover: passo 3, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Remove the back cover: passo 3, imagem 3 %32
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Unfasten the battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Unfasten the battery: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Remove the battery: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Remove the battery: passo 5, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Remove the battery: passo 5, imagem 3 %32
    • Lift the battery straight out of its recess and remove it.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Motherboard: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the connectors with bar latches by lifting up on the small bar behind the port and pulling the circuit ribbon away from the port.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the snap connectors by lifting straight up until the connection pops out.
    • Use an opening tool to pry them off if a finger cannot get underneath the connection.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 8, imagem 3 %32
    • Remove the latch connections by lifting the latch up, releasing the circuit ribbon.
    • Use an opening tool to get underneath the latch if a finger cannot.
  9. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the insert connections by pulling the connector away from the port.
  10. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 10, imagem 1 %32
    • Remove the seven 4 mm Phillips #0 screws that hold the motherboard in place
    • Remove the 3 mm Phillips #0 screw located near the fan.
  11. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 11, imagem 1 %32
    • Lift the motherboard with the fan still connected straight up and out of the device.
  12. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement, Keyboard: passo 12, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove sixty-six 0.5 mm screws from the keyboard.
  13. Lenovo ThinkPad X1 Carbon 7th Gen Keyboard Replacement: passo 13, imagem 1 %32
    • Lift the keyboard straight up and out of the computer.
Conclusão
6 outras pessoas executaram este guia.
2 comentários
I did this and the new keyboard only works for 1 minutes be for stopping
parker kerby - Responder
Where did you purchase the replacement keyboard from. I got mine from myfixguide and replaced using this tutorial. Worked flawlessly for me.
Rakesh S - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 105
Últimos 30 dias: 639
Duração total: 13,492
