Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: passo 2, imagem 2 %32
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
  4. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: passo 4, imagem 1 %32
    • Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
  5. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: passo 5, imagem 2 %32
    • Carefully peel the thermal pad off of the back of the SSD.
    • If the thermal pad is in good shape, you can reuse it by applying it to the replacement SSD.
Conclusão
7 outras pessoas executaram este guia.
Michael Megna
Membro desde: 01/23/20
1.310 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S19-G4, White Winter 2020 Membro de Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 Membros
Autoria de 23 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 65
Últimos 30 dias: 356
Ao todo: 22,747
