Introdução
In this guide, you will learn how to replace the motherboard in a Lenovo ThinkPad X1 Carbon 6th Gen. Be sure to power off your device and disconnect it from any power source before beginning.
O que você precisa
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
Remove each of the 7 main ribbon cables that connect the motherboard to the rest of the laptop.
Detach the last ribbon cable in the same way as before.
For the red and orange cables, use a spudger to lift the black plastic bar.
5 outras pessoas executaram este guia.
2 comentários
Step 3 should be removing the battery. There are 4 screws to do this.
is it true these boards have a problem and stop functioning? I bought it at Costco 2-3 years ago. My computer won't power on and my local tec shop thinks this is the problem. I like it bc is light and small and since I paid $1100 for it I think I should get a little more life out of it, right? I just bought a new battery too. thanks.
(X1 Carbon 6th Gen - (Type 20KH, 20KG) Laptop (ThinkPad) - Type 20KG; 8th Generation Intel® Core™ i7-8550U Processor(Core i7-8550U) Machine Type Model: 20KG0022US.)
