Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: passo 2, imagem 2 %32
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Battery: passo 3, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: passo 4, imagem 1 %32
    • Take out the battery by lifting it from the bottom edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: passo 5, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: passo 6, imagem 1 %32
    • Remove the cover by grabbing it and gently pulling up and to the left.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: passo 7, imagem 2 %32
    • Use a nylon spudger to lift up the black bar that secures the cable.
    • Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
Conclusão
Uma outra pessoa concluiu este guia.
Michael Megna
Membro desde: 01/23/20
1.265 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S19-G4, White Winter 2020 Membro de Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
Membros da 3
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 31
Duração total: 1,451
