Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 2, imagem 2 %32
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Fan: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement, Fan: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
    • The screws do not completely come off from the fan mount. Loosen until the screws are completely loose.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Nylon Tipped Tweezers
    Comprar
    • Use nylon tipped tweezers, or your fingers, to gently pull the fan's power cable towards the SSD, disconnecting it from the pins.
    • Be sure to pull on all of the cables at the same time.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 5, imagem 2 %32
    • Use a plastic opening pick to lift the fan mount.
    • Use your fingers to gently pull the fan diagonally away from where it is connected.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Fan Replacement: passo 6, imagem 1 %32
    • Turn the fan over to expose the interior.
    • If necessary, clean out the fan or wipe away and replace the thermal paste.
Conclusão
4 outras pessoas executaram este guia.
Michael Megna
Membro desde: 01/23/20
1.265 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S19-G4, White Winter 2020 Membro de Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
Membros da 3
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 65
Últimos 30 dias: 294
Duração total: 7,801
