Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement: passo 2, imagem 2 %32
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
Conclusão
Michael Megna
Membro desde: 01/23/20
1.265 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S19-G4, White Winter 2020 Membro de Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
Membros da 3
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 40
Duração total: 2,450
