Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: passo 3, imagem 1 %32
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Wi-Fi Card: passo 4, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the 1.2 mm screw that's holding the Wi-Fi card in place.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: passo 5, imagem 1 %32
    • Disconnect the white and black coaxial antenna cables from the Wi-Fi card.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: passo 6, imagem 2 %32
    • Slide the card out to remove it from the laptop.
Conclusão
Equipe
Gateway, Team 1-3, Saknee Fall 2021 Membro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 32
Duração total: 911
