Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 3, imagem 1 %32
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: passo 4, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, imagem 3 %32
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: passo 6, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, imagem 3 %32
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, imagem 3 %32
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
Conclusão
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Equipe
Gateway, Team 1-3, Saknee Fall 2021 Membro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Membros
9 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 328
