Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 3, imagem 1 %32
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: passo 4, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, imagem 3 %32
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: passo 6, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, imagem 3 %32
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, imagem 2 %32 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, imagem 3 %32
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
Conclusão
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Equipe
Gateway, Team 1-3, Saknee Fall 2021 Membro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 35
Duração total: 786
